NI TestStand
How do I access the Measurement array of a MultipleNumericLimitTest?
Here is a Csharp code snippet that I thought should work, but doesn't:
PropertyObject item;
if (item.GetValString("TS.StepType", 0) == "NI_MultipleNumericLimitTest")
string lowerBound, upperBound;
int numElements;
PropertyValueTypes elementType;
item.GetDimensions("Measurement", 0, out lowerBound, out upperBound, out numElements, out elementType);
for (int k = 0; k < numElements; ++k)
// **** This next line throws an exception - "Specified value does not have expected type"
PropertyObject arrayEntry = (PropertyObject)item.GetValVariantByOffset(k, 0);
if (arrayEntry.Exists("Status", 0))
this.currentResultData.status = arrayEntry.GetValString("Status", 0);
Can someone enlighten me as to what I should be doing to properly access the Measurement Array?
(3,339 Views)
Accepted by tlaford
I figured it out...
... should be ...
PropertyObject measurementProperty = item.GetPropertyObject("Measurement", 0);
measurementProperty.GetDimensions("", 0, out lowerBound, out upperBound, out numElements, out elementType);
PropertyObject arrayEntry = (PropertyObject)measurementProperty.GetValVariantByOffset(k, 0);
(3,334 Views)
It's probably better to call GetPropertyObjectByOffset instead of GetValVariantByOffset, then you won't need the cast and will give a better error message if it's not an array of objects.
-Doug
(3,306 Views)
