How do I attach keyboard short cuts to visible teststand buttons in a labview ui
On a normal labview VI it is possible to configure the desired key navigation options such as assigning a keyboard short cut to a control. Is it possible in some way also to assign keyboard short cut's to the visible Teststand Active-X controls i.eg. the Teststand button on a labview based custom UI ?
Please help Smiley Tongue
Claus,CLD
Message 1 of 8
(5,368 Views)
Accepted by PetrolHead
You may be able to do it by cloning every button, assigning a shortcut to the clone, and then triggering an event and calling the 'DoClick' method of the TestStand button - I say may as I can't verify that the DoClick method will do what you want.
Obviously can hide the clones on the front panel if neccessary.
David Clark
CLA | CTA
Genesee Technologies Ltd
Hampshire, England
Message 2 of 8
(5,347 Views)
Smiley Happythanks for your reply. Implemented and tested!
Claus,CLD
Message 3 of 8
(5,318 Views)
Maybe filter for VKey and ASCII values?
See attachment.
jigg
CTA, CLA
testeract.com
Message 4 of 8
(5,301 Views)
Alternatively, you can configure the shortcuts using the strings in the UIControlStrings.ini file, which defines the text that is used for the buttons.  It is located here:
<TestStand>\Components\Language\English\UIControlStrings.ini
In this file, the "&" symbol is used to define the hotkey.  for example, for the string "&Open Sequence File...", the hotkey is defined as "Ctrl + O".  I would recommend creating a copy of this file in the TestStand public directory, and modifying the copy rather than directly modifying this file.  this location is by default:
C:\Users\Public\Documents\National Instruments\TestStand <x>\Components\Language\English
Al B.
Staff Software Engineer - TestStand
CTA/CLD
Message 5 of 8
(5,289 Views)
Hi
Thanks for the reply.
I thought of this as well, but my challenge is that my customer specifies other short cuts than the default ones!
Claus,CLD
Message 6 of 8
(5,269 Views)
To Clarify, you can change the strings such that a new hotkey is assigned.  for examples, changing the string "&Open Sequence File..." to "O&pen Sequence File...", changes the hotkey to ctrl+P.  If the requirement is to change the modifiers, than this method will not be effective.
Al B.
CTA/CLD
Message 7 of 8
(5,256 Views)
Okay, now we are talking busyness !!
Claus,CLD
Message 8 of 8
(5,251 Views)
