NI TestStand
How do I change the standard width of the Columns of the Sequence Editor?
Always when I run a sequence, I get the same
standard column width. At the execution mode
I can't see all the information in the columns,
and I always have to resize them.
How can I set wider columns, so that they stay wide?
Thanks to you all!
With Regards,
- Caribe -
Test Engineer
SIEMENS AG, Germany
(3,197 Views)
Hi Caribe,
Unfortunately, that is the only control you have.
Regards
Ray Farmer
Regards
Ray Farmer
(3,191 Views)
Thats a pity,
maybe the developers of TestStand will
change this in laters releases, hopefully!
Thanks a lot,
- Caribe -
(3,178 Views)
