NI TestStand
can we open and read a file (.txt) with testStand?
Everything is in the message subject and if it is possible can you tell me how?
thanks
sole
(5,588 Views)
TestStand can only read specific types of txt files - for example with property loader step types.
If you would like to read a file as a string, you will have to call a code module in an action step.
(5,578 Views)
tahnks for your reply but have you got an example??
Message Edited by sole on 06-01-2005 03:49 AM
(5,572 Views)
The property loader example ships with TestStand.
It can be found at /Examples/LoadingLimits/LimitsFromTextFile/
For more information about the Property Loader Step Type, refer to Appendix D in the TestStand Reference manual.
Keep in mind, this CANNOT read a generic text file and give you a string. In that case you will need to write a code module (in LabVIEW, CVI, C++, etc...) and have it return you the string as a parameter. Is this the example you are referring to?
Allen P.
NI
(5,560 Views)
I have seen this example and I use it. It's ok when I make a file like this but without Labview. When I use labview it doesn't function.
(5,543 Views)
