08-22-2011 08:19 AM
If none of the Cases match the Select expression, I need to execute a specific set of sequences. How do I do that?
In C, the switch statement has a default case. I hope that TestStand has something as neat as that.
Solved! Go to Solution.
08-22-2011 09:38 AM
Of course it does 😉 Drop a Case step and on the Case tab in the Step Settings pane, tick the "Default Case" box.
08-22-2011 10:17 AM
Thanks!
