NI TestStand
How do I create a default case in a Select step?
If none of the Cases match the Select expression, I need to execute a specific set of sequences.  How do I do that?
In C, the switch statement has a default case.  I hope that TestStand has something as neat as that.
(6,520 Views)
Accepted by topic author jaime_c
Of course it does 😉 Drop a Case step and on the Case tab in the Step Settings pane, tick the "Default Case" box.
(6,518 Views)
Thanks!
(6,512 Views)
