How do I display a progress bar in TestStand and update it using expressions?
Subject says it all..
Dominik
(8,684 Views)
Do you want it to be a separate dialog?  Do you want to use a control on the UI?  Do you want to use the built in Status Bar progress?
The full-featured UI already has the status bar and you can update it with the following UI Message:
UIMsg_ProgressPercent–(Value: 11) TestStand step modules post this message to the user interface to notify it to update the progress indicator associated with an execution. The activeXDataParam parameter specifies an execution. The numericDataParam parameter specifies a value from 0 to 100 that indicates the percentage of progress the current execution reports. This value indicates the progress of operations for which the execution chooses to report the amount of progress. The value does not necessarily reflect the progress of the execution as a whole.
jigg
CTA, CLA
testeract.com
(8,676 Views)
I would like to use the built in status bar. Could you explain it step by step? For example, I inserted an expression step. What would I need to type in to the expression in order to change the progress on the built in status bar? A link to an example would be great too. Thanks
(8,670 Views)
Accepted by Dominik-E
I threw this together.  Let me know if it is enough or if you have questions.
jigg
CTA, CLA
testeract.com
(8,660 Views)
Yup, that answers it exactly. Thank you very much!
(8,645 Views)
What if I need a Separate Dialog box,
My requirement is to show a separate dialog box with the progress of steps.
(2,652 Views)
