NI TestStand
How do I generate a list of all VIs that are in a TestStand (3.1) sequence?
Can TestStand (3.1) generate a list of all the VIs that are included in the sequence?  I have a folder structure full of VIs and I know that not all are being used.  I'd like to identify the unused VIs.
(4,049 Views)
I hope there is no direct method to get the list of VI's, I will always try the following method
This is the fairly easy way to get the list of VI's used in the Sequence
 Invoke ' Edit -> Sequence File Properties ' and in the  Load Option set  ' Preload When Opening Sequence File ' , after setting this property close and  open the corresponding Sequence file
When the Sequence File is opened, all the VI's will be loaded in the Memory, so the below code in LabVIEW will list all the VI's in memory
Get VI's List
There is always other complicated Method, you have use the Teststand ActiveX to read all the Steps in the Sequence FIle and Get the Step names which has the LabVIEW Adapter.
I am using TS 4.2.1, hope above mentioned options are in the TS 3.1
AshwiN,
(4,044 Views)
There might be an easier way and that is to make a deployment image using the TestStand Deployment tool.
Regards
Ray Farmer
(4,037 Views)
Check out this example program that generates a List of All Code Modules Used by a Sequence File, including VIs.
Hassan Atassi
Senior Group Manager, Digital Support
(4,018 Views)
