NI TestStand
deployment with motion
Hi All, I am deploying a system that uses the the NI 73xx pallete. I have put together a VI called "Initialise Motion.vi" which contains the 73xx palette VI, "Initialize Controller.flx". Whenever I deploy and attempt to run I get the attached error telling me that the "Initialise Motion.vi" is broken but I can run the vi on the development PC. Does anyone know why this is happening? Thanks, Sean
(2,903 Views)
Accepted by topic author SeanJ
You need the NI Motion Device Driver installed on your target system. You can get the depolyment tool to run the NI Motion installer at the need of the deployment?
Regards
Ray Farmer
(2,902 Views)
Thanks Ray,
I included NI motion 8.2 and it works fine now.
Sean
(2,896 Views)
