NI TestStand
How do I log Revision of my sequence file into the database ?
I am trying to log the revision of my sequence file into the database. I have created a Locals.Revision string variable which is updated using the property loader. How do I take this variable and put this in a column in the UUT_RESULT table of the database ? Thanks for the help in advance.
(3,087 Views)
You might want to take a look at this thread.  We talked about sequence file revision numbers, where to store them, and the plusses and minuses of each technique.
How to display sequence file version in report?
(3,070 Views)
Thanks for your suggestion.
I found the following message more helpful since it shows how to take a Local variable from the main Sequence and log into a database column which is what I want to do exactly and it worked: http://forums.ni.com/ni/board/message?board.id=330&message.id=8155#M8155
(3,063 Views)
