NI TestStand
Is there anyway to direct TS panels into a tabbed display?
I am in the process of creating a custom operator interface for TS from an example given by NI. Is there a way to make the various panels that TS produces (Standard IO, Sequence Edit panel, etc) map to a tabbed display?
(2,954 Views)
By Sequence Edit panel do you mean the sequence editor? I'm not sure if I completely understaood what you are trying to accomplish. What would you like to see in each tab? Is there a specific reason you would like your application to achieve this functionality?
Thank you
Nandini
NI
(2,927 Views)
Yes. I have several Application panels that I am placing in individual tabs for screen layout issues. The random placement of TS panels makes the whole code look unorganized. From a user point of view, having the different screens fixed in "static" locations presents a more unified interface. With fixed placement the whole interface shold scale easily from one monitor size to another. The idea is to have all screens/panels fit inside the main TS panel.
Paul
(2,925 Views)
