Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do I run DLL but continue on using teststand?
MrSorensen
Member
08-30-2007
12:19 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I need to run a DLL in the background while test stand continues to run its sequence. Is there any way to do such a thing?
I will take any method possible.
0
Kudos
Message
1
of 4
(3,416 Views)
Reply
Re: How do I run DLL but continue on using teststand?
MrSorensen
Member
Author
08-30-2007
03:39 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I got it... you can multithread when you call a new sequence, so i just put the DLL in a seperate sequence and multi-threaded it.
0
Kudos
Message
2
of 4
(3,403 Views)
Reply
MrSorensen
Member
Author
08-30-2007
06:55 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
nevermind this multithreading in TestStand didnt work as I had hoped.
0
Kudos
Message
3
of 4
(3,396 Views)
Reply
AndrewMc
NI Employee (retired)
08-31-2007
04:44 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
In what way did the multithreading (via a sequence call) not work? Please provide details into what exactly you're wanting so that we can recommend a solution.
Andy McRorie
NI R&D
0
Kudos
Message
4
of 4
(3,377 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
