NI TestStand
How do I run DLL but continue on using teststand?
I need to run a DLL in the background while test stand continues to run its sequence. Is there any way to do such a thing?
I will take any method possible.
(3,458 Views)
I got it... you can multithread when you call a new sequence, so i just put the DLL in a seperate sequence and multi-threaded it.
(3,445 Views)
nevermind this multithreading in TestStand didnt work as I had hoped.
(3,438 Views)
In what way did the multithreading (via a sequence call) not work?  Please provide details into what exactly you're wanting so that we can recommend a solution.
Andy McRorie
NI R&D
(3,419 Views)
