NI TestStand
How do I use a Labview Enum as a Variable Parameter for Teststant
I have a Labview VI that performs a relay setup based on a Port selection that is an Enumerated  Type Def. The Control comes in as a drop dwon box in test stand. The question is how can I use that same dropdown as a variable to pass into a subsequence. I am not sure how to get it to show up as a custom  Type in test stand. I am using Labview 8.2 and Test Stand 4.0
(5,017 Views)
As of TestStand 2010 there is not a way to natively create enums in TS.  A quick google or bing search using "TestStand Enum" should reveal all those who have tried before you.  I believe that in the Ideas Exchange there is already a note to have TS do this and I'm positive the TS developers are aware... 🙂
In answer to your question you will have to save it as a numeric and pass it down to the sequence.  Or I kinda like this idea:
http://forums.ni.com/t5/NI-TestStand/Using-Enumerated-data-type-in-NI-Teststand/td-p/773312
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,011 Views)
