NI TestStand
Is it possible to add a delay between steps
I am using TestStand 4.2 and I need to add some delay time (maybe only 1-2 seconds) between two steps in one of my sequences.  I can not find a step type or command to do this currently.
(3,265 Views)
Use the Wait step.  On your step palette under the synchronization folder you'll see the Wait step.  Place it down and it should be intuitive what to do.
Let me know if you have any questions.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,264 Views)
