How do i read GetProcesses() from System 2.0 Assembly
I want to call a Exe programmatically from TestStand after verifing the system process names. I want to read all Process names and compare to make sure whether my application exe is running. I've found the System(2.0.0.0) assembly which needs to be called in order to get the process names.
I'm able to do this these steps in LabVIEW. Attached is the reference VI. But, similarly i want to do it in TestStand. I've started doing that; I'm struck here, how to read data from Array Obj Reference and populate ProcessNames. Apprecaite your help.
(3,389 Views)
Accepted by Blessing_Star
GetProcess() returns an array of Processes. You will get this to TS by using an array of object References.
Just Iterate throw the array by using foreach steptype to get each step name
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,344 Views)
