NI TestStand
How do you integrate TS with a LabVIEW AE?
I have a front panel (TS Front Panel.vi)  and a VI that does the work (Traffic Lights.vi).  I want TS to run the operation (Traffic Control.seq) similar to the way that my demo VI (Traffic Lights Demo.vi) does it.
Any help for a green TS user?  If my design indicates that I am so badly out-of-line that it cannot be fixed, I can accept that--just say so.
kc64
Message 1 of 8
(3,834 Views)
Hi kc,
I liked the demo.
I think that you are already mimicking your demo VI.  I don't think I fully understand your issue.  Do you need the Front Panel of the TS Front Panel to show all the time?  Why don't you just call the demo VI?
I made a few changes to keep your references and such consistant.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 8
(3,826 Views)
>>I liked the demo.
Thanks. :^)
Yes.
I am trying to replace the demo VI with TS.  I want to have just  Traffic Lights.vi used in TS and set the obj refs and do the looping under TS control.
Message 3 of 8
(3,821 Views)
I forgot to add:  when I run the TS seq, neither of the front panels of TS Front Panel.vi nor Traffic Lights.vi changes.
Message 4 of 8
(3,820 Views)
Created an example that shows one way to do it.  It's really too hard to explain everything in a post.
Basic things you ought to know about this example:
Run VI Asynchronously step creates a new thread for the TS Front Panel VI
Start and Stop TestStand Modal VIs inside of TS Front Panel make it Modal to TS
Passing properties to and from TS to the TS Front Panel VI is done using Get and Set TestStand Property VIs  You need this because it's in a different thread.  The Sequence Context is what allows you to do this.
Give it a look and let me know if you have any questions.
jigg
CTA, CLA
testeract.com
Message 5 of 8
(3,813 Views)
Jigg--
I am very pleased with your solution.  Thank you so much for your help.
kc64
Message 6 of 8
(3,781 Views)
Hey kc64,
Just came accross this example today and thought you might be interested as it accomplishes the same thing just in a different way-
http://zone.ni.com/devzone/cda/epd/p/id/6045?submitted=yes
jigg
CTA, CLA
testeract.com
Message 7 of 8
(3,743 Views)
Thanks, Jigg.  I am tied to the action engine code right now, though.
Message 8 of 8
(3,741 Views)
