NI TestStand
terminate button text centering
I resolved this issue (so I thought) a number of months ago.  Then I resized the screen a bit, and I'm seeing issues where my button text doesn't seem to want to obey my property settings (at least not completely).  Hopefully this supplemental info will help describe the situation.
(3,042 Views)
I found that if I made the button larger, and no word wrap occurs, the middle center works fine.  However, I'm hoping to be able to have the word 'Terminate' above 'Execution' - two separate lines, but on the same button.
(3,030 Views)
Hello mrbean,
The best way that I have found to accomplish your desired formatting is to include the necessary number of blank spaces before both of the words terminate and execution.  I was able to determine the number of each of these spaces at design time by simply typing in the appropriate field in the Property Browser.  Then, I took note of this information (i.e. number of spaces) for use when programmatically changing the text from "Reset".  I know this is not ideal, but at least it represents a feasible work around.
(3,006 Views)
