NI TestStand
How to Autoexecute sequence at startup ?
I know that I can run a sequence at startup with a commandline like
this:
"C:\Program Files\National Instruments\TestStand\Bin\SeqEdit.exe" -run
mainsequence c:\seq1.seq
But it only executes once. How can I start the normal looping through
more than one UUT with a commandline?
Martin Kellner
(5,559 Views)
Martin,
Look at the ChangesSince10.txt in TestStand 1.0.1. Use the following command
line.
testexec.exe -runEntryPoint "Test UUTs" c:\sequenceFiles\Asequencefiletorun.seq
Paul Mueller
NI
"Martin H. Kellner" wrote:
>I know that I can run a sequence at startup with a commandline like>this:>>"C:\Program
Files\National Instruments\TestStand\Bin\SeqEdit.exe" -run>mainsequence c:\seq1.seq>>>But
it only executes once. How can I start the normal looping through>more than
one UUT with a commandline?>>Thanks >>Martin Kellner>
(5,559 Views)
I didn't have the 1.01, when I started working on this problem.
Thanks a lot
Paul Mueller schrieb in Nachricht <38d62683@newsgroups.ni.com>...
>Martin,
command
>line.
>Paul Mueller
>NI
c:\seq1.seq>>>But
(5,559 Views)
