NI TestStand
file open based on StationGlobal?
I am working on a sequence that reads strings from a INI file. I would
like to use those strings as my filename called in a DLL action type. I
have stored the strings as Locals variables but I don't know how to specify
the Locals variable as the filename.
The DLL action wants a DLL Pathname to be specified in the Module tab but
I would like to use a dynamic name retrieved from the INI file.
I tried using the Evaluate(string) and the FindFile() expressions but all I
get is a "File Open" popup when I run my sequence.
Can I do what I want using the INI file?
Thanks.
-Steve
__________________________________________________________________________
Steve Heitke Phone: 630-378-6337
T
ellabs Operations, Inc. Fax: 630-679-3153
Advanced Test Methods email: heitke@tellabs.com
Bolingbrook, IL 60440 http://www.tellabs.com
(4,089 Views)
Steve,
You can programmatically set the DLL that you want to call. There are
hidden step properties which contain the information that TestStand uses to
call the DLL function. You can view hidden properties by enabling the
option in the Preferences tab of the Station Options dialog under the
Configure menu. Most of the hidden properties are self explanatory,
although they are documented anywhere.
You should look at an example, Dynamically Determine Which Code Module to
Run, which you can download from the examples database at
www.ni.com/support/epd/ Although this example doesn't demonstrate calling
DLLs, you can use the same concepts.
Paul Mueller
NI
Steve Heitke wrote in message
news:38c3bb98@newsgroups.ni.com...
> I am work
specify
I
> Thanks.
> -Steve
> Tellabs Operations, Inc. Fax: 630-679-3153
(4,089 Views)
