How to Change Active LV Development System
Hi All,
I previously had LV 8.6 installed and now I have installed LV 7.1 on my PC and now the TS LabView Adapter Configuration screen shows 7.1 as the Active Development System (not RTE). How do I change it back to 8.6?
Jim
(3,694 Views)
Just launch LabVIEW 8.6.
Regards
Ray Farmer
Regards
Ray Farmer
(3,693 Views)
Accepted by Jim_Flip
Hi Ray,
That sure was easy!!
Many Thanks,
Jim
(3,684 Views)
Jim,
Opening up LabVIEW 8.6 would make the active version of LabVIEW 8.6, but there is another way to specifically tell TestStand which version to use. In the sequence editor, select Configure » Adapters. Select Configure for the LabVIEW adapter to open the LabVIEW Adapter Configuration. From here you can select which version of the run-time engine to use or whether to use the active development system.
(3,666 Views)
