NI TestStand
How to Dynamically Change the Report StyleSheets in TestStand.
Hi Luke,
I cannot open the attached sequence file. File Format Error - the file is not a sequence file
Error Code: 17100 incorrect format Source:”TSAPI”
Please advice. I’m using TestStand 3.1.
Henry
Message 11 of 17
(1,742 Views)
Here's the file saved for TestStand 3.1
CTA, CLA, MTFBWY
Message 12 of 17
(1,737 Views)
Hi Luke,
I see the same problem. Please see my modified “test” sequence “Computer.seq”.
My TestStand GUI is set to “report.xsl”. I would like to dynamically change to “expand.xsll”
Henry
Message 13 of 17
(1,730 Views)
Hey Henry,
Check your report options and verify that the report format is xml. I think the default might be html for 3.1
Luke W
Message 14 of 17
(1,717 Views)
Hi Luke,
Do you mean Report Options in TestStand GUI?
What about if TestStand GUI is set to ASCII Text file?
Can you make my test sequence “Computer.seq” work correctly?
Henry
Message 15 of 17
(1,714 Views)
Hey Henry,
That is what I'm referring to, yes. The Stylesheet only seems to apply to XML and ATML formats. Are you restricted to using ACII for some reason?
Luke W
Message 16 of 17
(1,712 Views)
Accepted by topic author HenryG
Hi Luke,
After I switched my GUI default from ASCII to XML, the Report Options call back is working correctly.
I have been using ASCII because it is easy to share test reports, but now I was asked to switch to XML format.
You have been very helpful, you are the best!!
 Thank you very much,
 Henry
Message 17 of 17
(1,694 Views)
