NI TestStand
How to Find Size of a String in TestStand
I have a String ouput coming from a LabVIEW module. I want to read the Size of the response string and check it against a fixed value and if its greater than, then return pass else failed. How do I read the Size of a String in TestStand? Is there a property available for it or a inbuilt function?
(1,093 Views)
Accepted by topic author VBajaj
Use the Len() function to get the string length.
Santhosh
Soliton Technologies
(1,080 Views)
