NI TestStand
Teststand sequence analyse programmatically
I want to perform an Teststand sequence's analysis programmatically via the Labview API.
Does anyone have an idea please?
Thanks a lot
(1,331 Views)
Is there a reason for LV instead of the TS Seq Analyzer app?
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/teststand-api-ref/sequence_analyze...
Santhosh
Soliton Technologies
(1,315 Views)
Hi Santo,
Yes, to automate the analysis of multiple sequences at once, instead of running the analysis manually for each sequence.
LV is not mandatory, I'm looking for a methode doesn't matter the language
(1,303 Views)
Accepted by topic author NABIL2050
In that case, the Seq Analyzer executable automation from CLI would work with the right analyzer definitions and you can automate it from literally any programming language.
<TestStand>\Bin\AnalyzerApp.exe
Santhosh
(1,301 Views)
Thanks Santo_13 for the time and effort
This should work, I will test it
(1,298 Views)
I think that my problem is AnalyzerApp.exe can't analyse a simple sequence but a *.tsaproj
So I have to build it from my sequence and all folders..
(1,282 Views)
