NI TestStand
How to Get the step name of MainSequence from SequenceFilePreStep / SequenceFilePostStep?
I'm using SequenceFilePreStep & SequenceFilePostStep to get the test time of every step. Is there any way to get the step name of MainSequence that calls the PreStep & PostStep callbacks? Thanks
(3,546 Views)
You can get the name of the sequence by NameOf(RunState.Caller.RunState.Sequence).
Regards
Ray Farmer
Regards
Ray Farmer
(3,542 Views)
If you want the step name then use NameOf(Parmeters.Step)
Regards
Ray Farmer
Regards
Ray Farmer
(3,538 Views)
Thanks. I figured it out.
 TS_SeqContextGetCallingStep(td->seqContextCVI, &ei, &objStep);
 TS_StepGetName(objStep, &ei, &ptr);
(3,534 Views)
