Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
revert to previous saved sequence file
kphite
Member
04-04-2006
02:32 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
In LabVIEW you can revert to the previous saved version without having to close and reopen. Can this be done with a sequence file also?
kph
0
Kudos
Message
1
of 3
(3,118 Views)
Reply
Re: revert to previous saved sequence file
RayFarmer
Trusted Enthusiast
04-04-2006
02:56 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
No, you would have to close the sequencefile without saving then reopen it.
Sounds like a useful function, I know I made use of the LabVIEW revert in the past.
Regards
Ray Farmer
Regards
Ray Farmer
0
Kudos
Message
2
of 3
(3,114 Views)
Reply
kphite
Member
Author
04-04-2006
03:22 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks Ray. I'll submit it as an improvement to NI.
kph
0
Kudos
Message
3
of 3
(3,109 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
