revert to previous saved sequence file
In LabVIEW you can revert to the previous saved version without having to close and reopen. Can this be done with a sequence file also?
kph
(3,125 Views)
No, you would have to close the sequencefile without saving then reopen it.
Sounds like a useful function, I know I made use of the LabVIEW revert in the past.
Regards
Ray Farmer
Regards
Ray Farmer
(3,121 Views)
Thanks Ray. I'll submit it as an improvement to NI.
kph
(3,116 Views)
