NI TestStand
How to Put Serial Number in "UUT Information" Screen
Hi guys!
I'm reading the Serial Number using a Cemera and a 2D code on Units, and I would like to put the serial number in the corresponding box of "UUT Information".
At this time I'm puting the serial number on Report using "RunState.Caller.Locals.UUT.SerialNumber".
I need to keep the "UUT information" screen on front.
Thank you
(4,709 Views)
When I click "Next UUT" (without a serial number on the box), I'm reading the serial number using Camera and LabView signal procesing, I would like to write the readed serial number to UUT information Box...
It's any way to do that without modify and overide the PreUUT?
(4,665 Views)
I believe that you would have to modify ModelSupport2.dll. The source code for this is provided. You edit it with LabWindows/CVI.
(4,660 Views)
