NI TestStand
How to Remove the Login window on Teststand start ?
Hi, When i start the Teststand in evaluation version. there is a pop up window asking for the username (administrator) and password. and every time i have to click on OK button without any password to start the Teststand. Is there any option available in Teststand by which we can disable the pop up of LOGIN window at teststand start ? I know we can disable the occurance of LOGIN window but don't know where and how ? Can anyone help ? Thanks in Advance
Thanks and Regards
Gaurav Pal
(7,982 Views)
Check for Menu Configure-->Station options-->User Manager Tab-->Automatically login Windows user.
You will have to create a user with the same name as the windows login.
Refer help document on that.
(7,980 Views)
Or you can modify the LoginLogout in the FrontEndCallbacks.seq. That's where it gets launched.
Before you change anything override the original by copying FrontEndCallbacks.seq from here:
C:\Users\Public\Documents\National Instruments\TestStand 2010 SP1\Components\Callbacks\FrontEnd
to here:
That way you can revert to the original easy. There should be info in the manual about this.
cc
(7,962 Views)
