NI TestStand
How to build a TestStand 2012 workspace ( insert a project / insert a folder) programmatically using LabVIEW 2012 and the TestStand API.
Hi everybody!
I am just trying to find out how to create a TestStand workspace … in LabVIEW using the TestStand API.
To create a new workspace was quite easy. Unfortunately I am not successful to insert a new or existing project to the workspace.
Furthermore I have to insert a folder from disk to the new or existing project in the way that I can use an absolute path for the directory …
Maybe someone had already solved this problem, in any case  I am thankful for any hint. Smiley Happy
Greetings from Germany,
Norbert
(3,249 Views)
Have you find out how to add a folder to a project? I'm looking for this to... I tried WorkspaceObject.NewFolder[Name]whitout success...
For creating Workspace and project see the newer resolved thread I created.
Martin
(3,110 Views)
