NI TestStand
Message-Popup: How to display a number (from variable) in hex-format?
i have a numeric FileGlobal that is display in a MessagePopup-step with str(FileGlobal.param1)
How can i change this that it display the number as hexvalue.
For example if Number is a 10, then the MessagePopup should display a 0xA.
Thanks for help
(5,901 Views)
Accepted by topic author OnlyOne
HI,
You should try this expression Str(FileGlobal.param1,"%X",1 ,True)
Hope this helps
Rodéric L
Certified LabVIEW Architect
(5,899 Views)
I have a FileGlobal String with is an ASCII String with
How can I change this that is displayed as HEX String  like \x01\x02 ?
Is there someting like str(FileGlobal,"%x") ? -> this does not work 😞
(5,541 Views)
What you are wanting to do is escape the bytes of the string. Is this a LabVIEW binary string? What exactly are you trying to do? What is in the string that you are trying to escape?
-Doug
(5,526 Views)
