NI TestStand
How to Run teststand sequence file using the LabVIEW
Hi I want the execute the Teststand Sequence file using the LabVIEW .Net containers.I didnt find out the Execution Parameter in the .Net Container.Do you any suggestion regarding this question.Please let me know.
Jayavel
(4,428 Views)
TestStand comes with loads of Operator Interface examples some simple, some full fledged. You can find it in teststand public folder win7 path here:C:\Users\Public\Documents\National Instruments\TestStand 2010 SP1\UserInterfaces
You can take these examples or use ideas from here, also read the teststand reference manual. It has a section about Operator Interfaces.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(4,421 Views)
