Hi all
The test system was built by TestStand, now there is a new requirement to filter the test report without change the sequence file. The task must be done without any impact to previous software system, so I decide to write a tool by VC++.
My idea is to deal with the reports after every UUT loop, but I need to monitor the UUT loop status by VC++, if an unit is tested, pass or fail, raise a event and pass to VC++ application. In a word, I would like to access TestStand internal event and variables.
Anyone has ideal on this case? ActiveX or something.
thanks .
Rexxar
*The best Chinese farmer*
