NI TestStand
How to access to a specific sequences ran in parallel (new thread)
Hello
I have a sequence that I want to run as a clonable module (the equivalent in labview) due inside the sequence I generate a object reference and run a python script. The problem is that after that step i have another step where I call the other sequence but one of the parameters is the object reference created in the first step. So I would like to access to a specific sequence that I run in the first step to run the next script with my object reference. Any suggestion?
(1,079 Views)
Where are you storing the Object reference within that async seqeunce?
Local or FileGlocal?
(1,060 Views)
In file globals
(1,024 Views)
Make sure you don't share the FileGlobals
(1,018 Views)
Where do you access to that menu? I couldn't find it (I'm using teststand 2020)
(1,008 Views)
I have setted as you mentioned
(1,002 Views)
