How to append data into array?
As it's in question. Can I add data (new elements) into array dynamically? Let say my Numeric array 1D is size of three, but I'd like to add next three elements. Should I change array size first?
Cheers,
K
(18,184 Views)
If you use the option = 1 in the SetVal method this will insert a new element into the array.
PropertyObject.SetValNumber ( lookupString, options = 1, newValue)
If you want to re- dimension the array size use the following
(for 1D arrays)
PropertyObject.SetNumElements ( numElements, options = 0)
(for multi-Dimension arrays)
PropertyObjectType.ArrayDimensions
ArrayDimensions.SetBounds ( lowerBounds, upperBounds)
check out the help for each of these in the TestStand Programmer Reference.
regards
Ray Farmer
Regards
Ray Farmer
(18,170 Views)
Accepted by MimiKLM
Hi K,
Ray is right!
Maybe this thread will also help you because there is smal example
http://forums.ni.com/ni/board/message?board.id=330&message.id=18421&query.id=288653#M18421
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(18,166 Views)
A minor correction...
I'm fully aware that this thread is 13.5 years old, but I ran across it while trying to figure out if there's a more elegant way to append an element to an array.
If Locals.Foo is a 1D array of numbers and I try using option 1, which is PropOption_InsertElement:
Locals.SetValNumber( "Foo", PropOption_InsertElement, 123 )
,Locals.Foo.SetValNumber( "", PropOption_InsertElement, 123 )
In either case TestStand throws an error "Expected Number, found Array of Numbers."
However, the following does work:
Locals.Foo += { 123 }
This is more for the benefit of future readers running across this thread, as I know that @RayFarmer is a TestStand Über Overlord (an official title) at the time I'm writing this. 😎
(7,436 Views)
Hi guys,
I know this is old, but maybe you can answer my question, and help other who will be looking for this in the future.
I want to insert into array, not append.
I got this expression from the help:
InsertElements(MyArrayHere, ["my index here"], number of elements to insert here]
InsertElements(StationGlobals.SN_Buffer, ["0"],1).
This is accepted, but where/how do I specify the actual element I want to insert?
(7,368 Views)
