NI TestStand
How to change Group-name of custom step-type?
i´m using TS4.1 and miss a input-parameter which was avaiulable in TS3.5.
I have some labview-vis which should be TS-teststeps and they all shoul be placed in a group.
Do do this i open the "Types" and select one of my created types. The i rightclick the step and select properties.
In the tab "Menu" i can set a name for the step BUT the parameter to set the Group is no more available?
This was also in the Tab Menu in TS 3.5 but now in TS4.1 there is only Item-name.
Where can i set the Group-name od my steps?
Thx
Message Edited by OnlyOne on 06-10-2008 08:14 AM
(3,125 Views)
Hi!
Now you can go in the Insertion Palette in TS 4.1 (the Step Palette on the left side) and right click on Customize... (see attachement)
There you have the menu where you can change the group for all steps in the palette.
So now you have the possibility to change, create and move groups inside your palette.
Best regards
Ken
(3,101 Views)
Hi Ken,
thx for the help.
But this creating and moving was available before.
For me this is not an advancement against the old method to create the group.
It works, but needs more time/clicks.
I wonder who had the idea to change it.
(3,093 Views)
