Hello Rengith,
Below is some example code that should do most of what you would like. It will of course need to be customized to your needs, and modified to accomplish your specific tasks, but it should be a good starting point for you:
// Create the engine
Engine myEngine = new Engine();
SequenceFile mySeqFile;
Sequence mySequence;
Step myStep;
double lowLimit, highLimit;
string varName;
// Get the sequence file in question
mySeqFile = myEngine.GetSequenceFileEx("C:\\TestSequence.seq", 0, TypeConflictHandlerTypes.ConflictHandler_Prompt);
// Get the sequence in question
mySequence = mySeqFile.GetSequenceByName("MainSequence");
// Get the step in question
myStep = mySequence.GetStep(2, StepGroups.StepGroup_Main);
// Get the limits using the lookup string "Limits.Low/High"
lowLimit = myStep.AsPropertyObject().GetValNumber("Limits.Low", 0);
highLimit = myStep.AsPropertyObject().GetValNumber("Limits.High", 0);
// Get the name of the variable you are storing results in, may be different depending on adapter type
varName = myStep.AsPropertyObject().GetValString("TS.SData.ViCall.Parms[0].ArgVal", 0);
Console.WriteLine("The low limit is " + Convert.ToString(lowLimit));
Console.WriteLine("The high limit is " + Convert.ToString(highLimit));
Console.WriteLine("The property to store the value in is " + varName);
Console.Read();
// Release the sequence file
myEngine.ReleaseSequenceFileEx(mySeqFile, 0);
// Close the Engine
myEngine.ShutDown(true);
I would certainly suggest looking through our TestStand API Reference Help, which can be found
here, and specifically the document "Using TestStand API Objects", found
here.
NickB
Applications Engineering
