NI TestStand
display a sequence in sequenceview activx control with CVI
I am trying to display a teststand sequence in an activX sequenceView control for an user interface made with CVI. I had a look on the example of national intrument  (...teststand\UserInterfaces\NI\Simple\CVI) but my application is not exactely the same because all buttons are not ActivX controls.
So I try to display the sequence with this command:
TSUI_SequenceFileViewMgrSetByRefSequenceFile
but when i execute i have an activx error : File was unloaded from the test stand engine.
Can someone help me or having some example to help me.
Thank you
Regards
(3,249 Views)
Hi ,
There is another example on our web site (http://zone.ni.com/devzone/cda/epd/p/id/3550), with this one you can select on the menu the sequence, and after run it.
You can adapt it, if you seearch the funciton on the source code.
regards,
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(3,206 Views)
Hello
That's perfect, exactely what I need. Thanks a lot
Regards
Romain Esteoule
(3,199 Views)
