NI TestStand
How to change ResultRecordingOption depending on step result?
is it possible to create a preexpression in a numeric-limit-step which set the Result Recording Option = Disabled if the step is passed?
I only want to see the step if limit check failed.
Thx
(2,230 Views)
Any ideas about this?
The current workaround is to change the numericlimit step to type action and save the result in a variable.
Then add a new nonadapter numericlimitstep that checks the previous result and has a precondition to only execute if limit not in range.
But this requires two steps for all tests.
How can this be done in only one step?
(2,186 Views)
Accepted by OnlyOne
If you want to exclude all passed steps from the report, you could use a results filtering expression. If you just need it for specific steps, you should kudo this idea:
https://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Add-Result-Recording-Option-quot-Enabled-On-Step...
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,177 Views)
Thanks for the link. as i see also other want to have this solution.
I dont want to specify this for all steps. Only for some.
But it looks like that this is nit possible with TestStand.
(2,153 Views)
