NI TestStand
How to change StationGlobals on Base Depolyment Enginge
i have system that was in the beginning licenced to Development System.
Now i changed the licence to Base Deployment Enging as it is only used to execute testplans with a custom GUI.
The question is now: How can i add, change, modify the StationGlobals on a Base Deployment-Engine-system?
(2,392 Views)
Accepted by OnlyOne
1) You could add, create or modify you StationGlobals on your development system then deploy the StationGlobals.ini file to your target system.
2) You could have a SequenceFile which has a Sequence that you can run on your target system to setup your StationGlobals. It could perform an Engine.CommitGlobalsToDisk so you didn't have to shut you UI down.
Regards
Ray Farmer
(2,378 Views)
