NI TestStand
How to change the step background in Teststand?
  I have a requirement for Teststand. I can not find a function to set the background color of steps/sequences in Teststand sequence editor.However, sometimes, it becomes so important that I prefer to have this function since sometimes we want to highlight some steps, See attached file. Is there any method/recommendations to do this for current teststand3.1?
Thanks!
Jacky
(3,579 Views)
You right click on the execution window while you are editing the top level OI. Select SequenceView Properties.
Click on the 'columns' tab.
Take the example from  Background Color Expression for 'Status' and copy it to the other columns (name and description)
This should give you a place to a place to start.
(3,558 Views)
