NI TestStand
move teststand workspace to another path
We need to move a Teststand workspace with all included files to another path. In many cases the used configuration files are in text format . So you can search and replace a text editor to adapt the path. One exception are the configuration files for the deployment utility ( .tsd files). Is there any way to adapt the paths in these files without remaking it from scratch ?
(3,027 Views)
You must load the configuration in the "deploy teststand system" tool and adjust the paths there. I don´t see another possibility.
Best would have been to not use absolute pahts, but to use relative paths or the search directories.
(3,019 Views)
