How to check from within the subsequence has the sub-sequence passed or failed?
I need quick help:
At the end of the sub-sequence in the CleanUp section I'd like to check has this sub-sequence passed or failed?
How to do this?
K.
(5,721 Views)
One of the way to do it  :
Changes in the test sequence :
Add engine callback - "SequenceFilePostStepFailure" to your test sequence.
Create a passfail flag in fileglobals.
In the engine callback put a statement which sets the flag to True.
For the sub sequence do the following :
In setup set this flag to false
In the cleanup check if this flag is true
This flag will be true only if any of the steps failed in the sub sequence
Hope this helps.
Ravi
(5,712 Views)
Can't I not use something what is already built-in in API?
Maybe there is Something under RunState... API menu?
(5,710 Views)
Accepted by MimiKLM
I think you are looking for Rustate.SequenceFailed.
(5,703 Views)
That's it!
(5,678 Views)
