NI TestStand
How to configure call library function to call function from dll that has struct with arrays.
I have this function in dll:
DLL_EXPORT unsigned GetResultSample_Image(void * pHandle, unsigned long zero_based_index_of_result_sample, TestResult_Image * pTestStatus);
The parameter TestResult_Image is defined in .h like this:
struct TestResult_Image
uint32_t position; uint8_t arrayFixedSize[64]; };
 I don't know how can I configure call library function node for struct TestResult_MISImage.
Element arrayFixedSize is an array with 64 bytes.
Before calling function GetResultSample_Image I have to call function StartTest_Image, that is defined like this:
DLL_EXPORT unsigned long  StartTest_Image(void * pHandle, TestParameters_Image * pTestParameters);
Where TestParameters_Image is defined like this:
truct TestParameters_Image
	uint32_t voltage;
	uint32_t resolution1;
	uint32_t resolution2;
	uint32_t number_of_image_samples;
In this function I define how many images I want from GetResultSample_Image function.
So If I type "number_of_image_samples=5", then the function GetResultSample_image will return 5 elements: TestResult_Image with 5 different elements "arrayFixedSized[64]"
I tried to configure function like this:
But it does not work and the LV crashes every time function is called.
(2,320 Views)
can you upload your code? It's hard to say anything if we don't see what's happening.
With which error LabVIEW ends?
Have you checked these links?
(2,250 Views)
