NI TestStand
How to create 2D array of pictures in Teststand
I have created 2D Array of pictures in Labview:
I want to pass this array into Teststand but TS cannot accept 2D Array of pictures. What can be work arround this?
(2,413 Views)
Accepted by AndrazS
You can save it to a 2D Array of strings in TestStand.  Just make sure that when you pass it into TestStand you choose the type to be 2D Array (Binary String) on the Module tab for the LabVIEW step.
I just tested this and it worked great.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,378 Views)
Thanks this was the solution!
(2,316 Views)
