How to create Custom Step Types: Is there any example?
Dear all,
I remember years ago I've read an NI page with  a detailed procedure for creating Custom Step Types. Additional LV code and .DLLs were provided for download, but now I'm not able to find anything anymore...
The example was about creating a new Extended Numeric Limit Test type.
 Could anybody help me?
Thanks in advance!
Giovanni P.
Certified TestStand Developer
(6,189 Views)
Giovanni,
A good high level document for this is Best Practices for Custom Step Type Development. We also install several custom step type exapmles in the following directory -
%TestStandPublic%\Examples\Custom Step Types
Hope this helps!
Trent
(6,162 Views)
Hi Trent,
In the past I had downloaded the attached PDF document from the NI site. Even if it refers to an older TestStand version it's quite accurate and it would be fine, but I can't find the DLL the example refers to (which was supposed to be linked to the page).
The DLL provided the functions to be executed for the Edit and pre-step Substeps..
(6,145 Views)
I think I found it. See the attached zip.
-Trent
(6,134 Views)
Accepted by giovanni.alfamation
hank you very much Trent!!
(6,110 Views)
Sorry Dear Trent,
but Not executable.the extendedlimitsdialog.uir file is missing
(5,383 Views)
