NI TestStand
How to detect any changes of a StepType-field by the sequence ?
Hi all,
suppose I've got this: a simple StepType 'TEST' with one added custom field 'Source' of the type String.
When using this StepType in a Sequence and editing the 'Source' value (from the Variables panel),
the Sequence name is immediately marked with an '*'. Which is wat we want 🙂
But, if I change the 'Source' value from code (C#), I see that my 'Source' value is changed (in the Variables panel), but not that the Sequence has detected this.
Maybe it's StepType-flag that I have to set or from code, executing a trigger or so ?
Thanks in advance ?
Franky
(3,824 Views)
A quick answer to myself :  use the property flag PropFlags_Shared.
(3,819 Views)
Way too fast !
Using the property flag PropFlags_Shared is not a solution, because that flag sets a field as a shared object, which is not what I want.
(3,807 Views)
Accepted by FOstyn
I'm talking to myself, but FYI:
because I'm updating my sequence from code (C#), I've the current Step as an object and
therefore I knows if any fields are changed.
Using this snippet will mark my sequencefile as 'changed' :
step.Sequence.SequenceFile.AsPropertyObjectFile().IncChangeCount();
(3,802 Views)
Correct. Whenever you programmatically edit a sequence file, you should increment the file's change count in order for the sequence editor to detect that the file has been modified.
-Doug
(3,793 Views)
