NI TestStand
How to disable tooltip
I would like to disable the tooltip (kind of contextual help) that appears when I write something like Str( in an expression field.
I use TestStand 2013
Thanks!
(4,565 Views)
Accepted by topic author Fanny_Gaillard
Whilst i fnd this feature extraordinary helpful (equally to auto-completion), you can de-activate this in the Station Options >> Preferences >> Expression Editing Options.
Norbert
Norbert
Expert: Geometry
(4,563 Views)
Thank you!
Yes this option is usefull but drives me crazy because I have a lot of things to write and the tooltip of Str is very big and I can't take my paramaters to drag and drop to the expression field... So I will enable it when my very big expression will be finished.
(4,554 Views)
