NI TestStand
ModuleTime in Step Callback
hi all,
I save the results of my steps in diadem using  " SequenceFilePostResultListEntry  " callback.
I am able to read the results from the  calling step or subseq   in my resultlist callback & save them in tdm format.
The  problem is  reading  ModuleTime.
Tried  diff ways , the  Expr. below gives inconsisten results.
RunState.Caller.Locals.ResultList[0].TS.ModuleTime
has anyone  worked on similar situations.
also  I was unable to find the Date format  in Teststand.  I have to  channel this date info to a  VI which writes the TDM file.
(4,397 Views)
Try:
PropertyExists("Parameters.Result.TS.ModuleTime") ? Parameters.Result.TS.ModuleTime : 0
You should not be accessing RunState.Caller.Locals.ResultList from the SequenceFilePostResultListEntry. The most recent result for the result list is already given to you as a parameter to the callback (i.e. Parameters.Result).
Hope this helps,
-Doug
(4,380 Views)
thanks Doug!    that was it.
(4,375 Views)
