How to enter Batch serial number from scanner
I have a batch process model with 4 test sockets.
If I press Run UUTs, batch info dialog appears and I have to enter batch serial number and serial number of sockets by hand.
How can I change the model so that (for example) I scan Batch serial number of my panel with 4 pcb units on it and test starts automatically? (no typing serials by hand). Also when I scan batch serial number I know (from my work order) witch pcb serials are on panel..
(3,831 Views)
Modify PreUUT to scan data instead of Waiting for user .
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,825 Views)
Thank you for advice.
Can You show me where and how can I change this?
(3,815 Views)
Accepted by Skoda3
Sorry its not PreUUT its PreBatch, In TestStand Model Sequence-> Batch Model, Modify the main Stepgroup for Scanning instead of Dialog box.
(3,812 Views)
Accepted by Skoda3
(3,811 Views)
Thank You!
Another question maybe this should be a new subject...
I want to do some setup stuff before MainSequence in Batch model starts...If some error accurs in PorcessSetup I want to exit the program.
How can i realize it?
(3,786 Views)
Accepted by Skoda3
Based on the error condition decide whether to continue testing or not?
Feed the Value to Parameteres.ModelData.ContinueTesting
(3,779 Views)
